1 - 2 of 2 Posts
Good question. I have never noticed before. You can compare maps on the PCIII and the PV but there seems to be no option on the PCV. I even tried to open 2 PCV windows but it won't even let you do that. When you try it gives you a warning that "this application is running. This instance will be terminated". You can open 2 windows in both the PCIII and PV and they both have the compare feature but not on the PCV.
Found this on the HDforums, maybe it will help.
http://www.hdforums.com/forum/touring-models/525686-need-pcv-map-comparison-tool-here-it-is.html
1 - 2 of 2 Posts
