1 - 20 of 55 Posts
I see it mixed in through a lot of the posts here, so how about a comprehensive list? I'm in the market for bars and I know those of you that have/had apes went through the trouble of figuring out which height to get.
So how about including:
Your Height -
What height bar you went with. (If tried multiple heights, which ones you started with then what you settled on.) -
Which brand of bar you went with -
Did you use stock cables? - Y/N
What year RG? -
Did you swap riser bushing? Y/N
Different seat?
Ride safe!
I think unless you are really short or really tall it is just a preference.
Your Height - 6'3"
What height bar you went with - 13" on a 2016 and a 2017 Road Glide
Which brand of bar you went with - Road 6 Customs (twice, they are good and very well priced)
Did you use stock cables? - Yes
Did you swap riser bushing? No first time, Yes second time. I recommend doing it while the bars are already off.
I'll volunteer,
5'8" 200lbs 32" inseam, don't know my arm length
I have 10" Appleton Customs now, very comfortable, set me up straight, but I do a lot of slow speed maneuvers (practicing) and my arms tend to get a little tired quickly.
I'm going to be putting 14" on soon, will update.
PS, no cable or wire changes with 10's, plenty slack left.
Your Height - 6'-0"
What height bar you went with. (If tried multiple heights, which ones you started with then what you settled on.) - 12"
Which brand of bar you went with -Todd's Cycle
Your Height - 6'1"
What height bar you went with. 12"
Which brand of bar you went with -Bad Seed Cycles $235 shipped
Did you use stock cables? - YES
Did you swap riser bushing?No but eventually will since taking the bars off is super easy.
Height-6'2"
16" on my 2005 Road King back in the day (custom engraved eBay purchase)
19" on my 2008 Electra Glide (a little tricky at slow speed turns/maneuvering in a parking lot)
16" on my current 2013 Street Glide (1 1/2" dia. Stepped down at the grips and steering column mounting)
Magnum Shielding Black Pearl wiring extension kit.
Stock mounting at the yoke.
Your Height - 6' 3"
What height bar you went with. (If tried multiple heights, which ones you started with then what you settled on.) - 16" on both roadies, tried the Heritage bars from HD on the 08 b4 I purchased the 16's. Took one 800 mile trip and ordered the 16's, I felt they were worse than the stock for me.
Which brand of bar you went with - LA Choppers on both, 08 has Blk Powdercoated Apes, 09 has Chrome Twin Peaks style
Did you use stock cables? - Y/N No
Did you swap riser bushing? Y/N Yes just to be on safe side
2008 FLTR & @009 FLTRSE3
HD Road Zeppelin (with Compressor) Seats on both.
Your Height - 6'3
Which brand of bar you went with - Factory 47
Did you use stock cables? - N
Sent from my XT1650 using Tapatalk
Your Height - 6'6
What height bar you went with. 16"
Which brand of bar you went with - Carlini
What year RG? - 2013
5' 11"
Carlini's Pist 14"
Barnett clutch cable
Stock brake line
New bushings
Wire extensions
2013 RGU
6'3"
16's
Factory 47 Malo's
Yes bushings
Black Shielded cables
2006 RG
Factory Seat for around town / Factory Pillow Seat for touring
Soooo much better than stock!
1 - 20 of 55 Posts
