1 - 9 of 9 Posts
I have ARC 125.2 mini amp with 6 1/2 inch 602 moto speakers with 6 1/2 inch adapters.Amp was used to run faring speakers and speakers in lowers with plenty of head room,this is a very powerful and extremely clean sounding amp.This combo has only seen about 2000 miles of use,bike was always garage kept and I am original owner.Only reason for sale is bike was sold.This combo sells for over $800,amp new $380,speakers new $380,adapters $50,selling for $385.You can call if you like,contact is 318-623-1400,thanks Paul
Are there any modifications to the speaker buckets in order to use those speakers ? Also how does the amp mount meaning does it come with some bracket for a 17 or is it something I have make myself ?
No mods needed for your 17 it uses 6/12 inch speakers so no need for adapters.just plug and play.As for the amp no mounting hardware needed just velcro to the side of inter fairing by glove box.it's a very easy install plug existing RG speaker wires into amp harness,plug wires coming out of amp to 602 motors speakers,then hot and ground,that's it
Wow ! Yeah in my old bike that's where I stuck the amp but this time around that doesn't look like a viable place. Almost every write up I've seen the amps go underneath the radio behind the headlight but I don't know if Velcro Aline will be enough to hold it there since there's nothing underneath to hold it from falling down. I'm going to do some homework on this. By the way why are you selling it and not mounting it into your next bike ?
arc offers a adapter kit/plate for 2015 through 2017 for $35 that mounts under radio that you do not have to drill or alter anything so HD warranty is not void.
PM sent
1 - 9 of 9 Posts
