Up for sale is a used 2 channel mini amp and power wire with speaker wires. Removed it from previous roadglide before trading. Worked great when removed, now have Cvo so don't need it. $125 plus shipping. PayPal accepted. Wire Electrical wiring Technology Electronic device Electronics
Product Technology Audio equipment Electronic device Electronics
Discussion Starter · #2 ·
Hi Level speaker inputs for OEM application and integration from most factory radios allowing you to retain all of the factory steering wheel/handle bar controls and features.
Mosfet power supply
Stable to 2 ohms stereo
Low Radiated Noise for Clean AM/FM/ reception
Power Output at 4-Ohms: 70 Watts x 2 at 14.4V
Power Output at 2-Ohms: 125 Watts x 2 at 14.4V
Power Output at 1-Ohm: Not Recommended
Power Output at 4-Ohms Bridged: 250 Watts at 14.4V
Power Output at 2-Ohms Bridged: Not Recommended
Total Harmonic Distortion: 0.05%
Frequency Range -3dB: 10 Hz - 50Hz
Crossover Range: 55 Hz - 550 Hz
Bass Boost: 0-15dB at 45 Hz
S/N Ratio (A wtg) ref 1 Watt 4-Ohms: >92 dB
Separation: >75 dB
Damping Factor 25W out 4-Ohm 100Hz: >800
Input Sensitivity (RCA): .3V - 3.5V
Input Impedance: 13K Ohms
Dimensions: 8.25"(L) x 4.8"(W) x 1.7"(H)
