I am getting interference noise from my speakers.
My System consists of:
Sony DXMS 60 head unit
Biketronics radio install kit and controller
Hawg Wired Reference 400watt amp
2 Hawg Wired ZX 6.5" speakers in the fairing
I originally wired the setup using Low Level inputs (RCA to 3.5mm jack), and would get engine noise upon sart up and the tone would very with RPM so I checked my grounding (4ga wire from neg batt to radio cradle and a 4ga wire from cradle to Amp) at that time I added a ground wire from the radio to the cradle and nothing changed. I was fed up so I pulled the fuses and have not had a radio for the last year.
This week I decided to fix it before my 2500+ mile ride in 2 weeks. I replaced the RCA to 3.5mm adaptor thinking that it was bad, but that didn't fix it. So I dug around the garage and found the High Level harness and tried that but still have interference. Also noticed that I could faintly hear it even with the engine off.
Any help or ideas on what to check?
