Has anyone put tweeters/speakers in 2 of your gauge spots? If so what did you use? Which gauges did you remove? Did they work well?
You should be able to search the audio threads, (or hopefully somebody will post some of the links), it has been done by a few. As far as gauges removed, air temp is definitely the first to go, I forget the other. I personally use all my gauges and replaced the air temp with an oil temp gauge. My tweets are mounted in the speaker grills.
Sent from my SPH-L710
I'd get rid of the fuel Gauge and just go off my trip meter. I agree with DBell though, there are other places to mount a tweeter that achieve the same effect. The metal Hawg Wired grills can be cut to accept a tweeter.
Sent from Motorcycle.com App
Hawgwired grill cut for tweeters.
My cvo already had tweeters, so it was a quick speaker upgrade for me. I would think swapping the gauges for speakers would be a relatively easy undertaking. Maybe someone who's done it will chime in soon.
