1 - 4 of 4 Posts
My stereo went out after an aggressive wash job Saturday. Needed to get her clean for the year and I needed the therapy. It was a 3 beer project. It actually ran for a while after I finished but then stopped. I let it sit for 2 days to make sure it was dried out. First I changed the fuses (4 & 5). I checked the error messages and got nothing and I am getting some power to the unit because I can put a CD in and take it out. Currently I am running stock head unit, arc mini amp and hertz speakers. Any thoughts on if this is shot. Or is it too hard to tell from just this limited info?
Sounds like the amp my be gone. Did you check the fuse for the amp ? It should be close to the battery. If its good ,Take the fairing off and bypass the amp.
Thanks Gary, that is what I suspected, but if the CD player is operating. I thought I would get some readout on the head unit. I can't even get the HD logo. The fuse is attached to the amp on my amp (ARC KS Mini 125.2 Mini) so I will be pulling the ferring and working from there.
Sounds like there could still water in there then. I once got water in my amp on an old ultra, when they put them under the tour pack. It took over a month for it to dry out. Ever since , I never spray water with any pressure directly at anything on the bike.
I'd still pull the fairing to run a few checks.
1 - 4 of 4 Posts
