1 - 2 of 2 Posts
Hi. I'm a new RGU owner, and was curious if anyone knew the amount of available wattage for accessories (like heated gear) on the 2011. I know HD upped the alternator output in this model, but the owners manual doesn't really tell you what the "base" wattage draw of the motorcycle is and what's left over for accessories.
If anyone knows the answer, it would be appreciated.
Thanks,
Al
Southern NH
I have a feeling that 20amp would be for ignition 10 amp for the headlights and so you are left with about 25amps for accessories. If you are so inclined you can always add in a delco or delphi single wire alt and run it off your primary... I saw a conversion one time but can't remember manufacturer
1 - 2 of 2 Posts
