1 - 3 of 3 Posts
Go to your "User CP" then on the left you will click on "Edit Signature".
Under the Signature box you will find a "Signature Picture" area. If you are loading the picture from your computer, click on "Choose File" to open the library on your computer. Once you have found the picture file you want to upload, double click it to insert it into the "Choose File" blank.
After that, click "Upload" under the "Choose File" button. After you have uploaded the picture, there will be a slightly hard to see button beside the picture that says "Insert Signature Picture" (the words should be easy to see).
After you click on "Insert Signature Picture" the you will click "Save Signature" below the "Signature Picture" box. You should be good to go from there.
1 - 3 of 3 Posts
