I have my C V b-54 mounted and I need to know the + and - to each channel. Had calls into tech support all week but they don't answer phone and don't return calls. I have a purple/green and a slate/white with corresponding black stripes on each set. ALSO do you run the turn one mode to VOX? Thanks for any help.
Thanks Guys, I have a manual But am still puzzled on the color code. I am taking the amp out today to make a final trim on the aluminum bracket I made. Since I posted I took a good look at the wire harness I bought from Biktronics and noticed that their color code going to the speakers are the same as the C V b-54 out put wires. I guess I could try just wiring color to color?
I don't know if you figured this out, but the color codes and the manual are confusing. Your answer is printed right on the amp where the speaker plugs insert.
