Hi All,
Can any one point me in the right direction. what does b1121 left turn output open mean? My left turn signals are not working, checked bulbs and fuses, no problem found there.
If you have had the fairing off, there may have been a wire pinched or broken where the turn signal wires feed thru the fairing mount.
that is exaclty what happened, loosened the fairing, reattached the turn signal, and VOila!!
Never would have figure out without your guidance!! Thanks a lot!
Now you need to check those wires real good if you didn't already. I'm sure you have some insulation that's rubbed off.
