Sissy bar or rider backrest?
Rider backrest. I have the fixed riders seat backrest. It has two bars about the size of rebar. I would like to bend them, but don't know how.Which one do you have? One of my buddies has the HD adjustable one and he bent the flat stock that goes into the receptacle a little bit so it moved the pad portion of the backrest back a bit. The metal stock is about 3/16" thick so I think he did his at work (a metal shop).
Lil Chief
I will give it a shot.I would think that if you mount the backrest, put the bike in 1st gear (not running) and the sit in the seat and push back on it you may have some luck bending it....
How could that be. It comes straight up from the bracket. I ask at the dealer, and said it was back as far as it goes. It is pushing on the seat where it comes through.Do you know that the bracket that bolts on the fender works assbackwards, the farther back it is mounted the more forward the backrest is and vise versa, the more forward you mount it the farther back the backrest is. (if it is the type with 3 sets of mounting holes).
Not much help I know, but that don't look right.
Lil Chief
My Kuryakyn backrest mounting bar has a dogleg in it. You can flip it to go back/forward. Fine adjustments are done to the mounting bracket under the seat.
Cool, glad ya got it adjusted to your liking.
