1 - 4 of 4 Posts
Bagger Bags Integrated LED Wiring - Solved
Hey Guys,
So i am wrapping up my install of the Bagger Bags 4 inch extended bags/fender with their integrated led lights. I am very close with the wiring and just need to add a circuit for each blinker (I think). With the below pic everything works except when i hit the blinker both start flashing. Any advice would be appreciated.
[/url]
screen capture software[/IMG]
Your diagram has the blinkers and brake tied together, you cant do that without a module or a complicated series of diodes/relays but basically thats what the module is. Anyway if you want to wire it as is with no module you need to choose either brake or turn for your bright filiment, the low filiment is your running light.
An inexpensive way to acheive stop/run/turn would be to use a trailer taillight adapter if you have room to hide it.
HTH..
1 - 4 of 4 Posts
