1 - 1 of 1 Posts
Anyone install one of these and get the hub nut tight WITHOUT buying/using the Barnett Clutch lock plate tool?
The tool is only $25 but I don't have one and trying to get this thing finished up.
Barnett pressure plate is solid, Harley one has a hole in the middle.
Harley you can put a socket on the hub nut with the plate on and the clutch hub and basket lock together because the clutch is engaged.
Barnett you need the pressure plate off to get access to the hub nut which means the basket and hub spin because the clutch cant engage without a pressure plate on there.
1 - 1 of 1 Posts
