1 - 2 of 2 Posts
This morning going to work, about 3 minutes into the ride my This morning going to work, about 3 minutes into the ride my Batt & Low Fuel light came (over half full) on looked at the Volt meter it showed about 11.75. I slowed an turned around then the idiot lights went off so I turned around again and rode to work 50 Mi.and everything seems fine. Was that a warning that my stator or ECM is going bad?
It could be as simple as a loose battery cable or bad/corroded electrical connection, etc. I would start with checking you battery cable ends (both ends of both cables) for good connections and then checking to see if you have any stored Diagnostic Codes.
1 - 2 of 2 Posts
