Hey gang. Darned if I can figure out where the ground from the battery to the frame/engine is. Does anyone have a picture or can tell me where it would be? I suspect I have a loose ground/corroded ground (meter on dash only shows 11 volts going down the road). I'd like to check the easy things first. Have a new battery in with 12.68 volts when sitting.
2009 FLTR
Thanks in advance.
Bruce
Well ya know the hot goes to the starter and ground to the motor/frame, check from the starter hot to the bolt head by the oil return side of tranny with multi-meter set 20v for batt volts then on batt
Discussion Starter · #4 ·
That gives me 12.57 volts. So, why does the meter read 11.5 volts at 3000rpm? Should it not read the same for the meter on the dash and what I get with the DVM?
BG
