Ok, so I have a 20' RGS and keep it on a Battery Tender Plus all the time. I rode for about 45 min up the highway, stopped and had breakfast and hung out for about 90 min. Volt meter reads 14 while running. Turned igntion on, all lights, fuel pump came on like normal, hit starter switcth and nothing. No crank, no start.
I have an Antigravity micro start XP-1 and associated pigtail hooked to battery. All connections are clean & tight. Plugged in XP-1 and biked started with slight delay on cranking. Not slow or weak, just not immediate. I didn't wait long once I plugged in xp-1 before starting.
Headed out and rode for about an 1.5 Hrs, stopped and hung out, had lunch. When leaving, bike started but cranked a little slow before starting. Volts read 14. Rode back for an hour, parked bike for 2.5 - 3 hours. Time to head out, turn ignition on, all lights come on, no crank, no start again. Used Xp-1 again, took a few tries to get it to fire but it started and I made it back 45 min to home and parked it.
I let it sit for a few hours, started right up.
I left it off the tender for the night and checked voltage in the morning - 12.25 and 10.2 at crank, 14.1 at idle.
I did this same test over next few days, lowest reading 11.38 / 8.9 at crank, 14.1 at idle. Started no problem, no hesitation.
The pigtail for the XP-1 is the only accessory that I have added to the bike that requires power. Honestly, I put this in my bag as a part of a growing tool kit I am putting together. Thankfully, I had it.
I am using a digital probe, I don't have a multimeter so I haven't check for parasitic draw yet.
I did check codes and it shows U0100 - Lost communication w/ECM under the radio, none on ecm, bcm or abs.
I do ride with a Cardo Packtalk and was having issues with it toggling back and forth between bluetooth on phone and FM on radio. Kept losing connection like it was buffering.
I admit, I'm not great with electrical but understand some basics.
I appreciate any thoughts, advice and help on this. I am reluctant to get stranded somewhere and not be able to get it started with the XP-1.
