1 - 20 of 48 Posts
Looking to take factory speakers out of my 13 fltrx and would like some opinions on the best speakers out there for under 150. Would like something that I can put a amp to later on down the road as well
I replaced my front fairing speakers with the JBL GTO638 6x5's. They sounded great without an amp and then I installed an ARC audio KS125.2 to them and I'm no giddy like a kid on Christmas.
I've got two options for you.
1) DD CXS 6.5- These are coax so they have a mid driver with built in tweeters. I have 4 of these pushed by an amp on my 13 RGU. They are 4 ohm, capable of handling 150w max. They are loud and clear even at highway speeds. My wife instantly noticed the difference over stock. I got them for $100 (pair) from Syracuse Customs in NY.
2) DD VO-M 6.5- These are a mid range driver, capable of handling 300w max. These are probably twice as loud as the DD CXS, especially when hooked up to an amp. These are PERFECT when tied to a set of external tweeters. You can get these for 140-160 a pair, depending on where you get them.
Digital Design is a new up an coming company, so not many people have heard of them yet. If you talk to Chris Lowe (Garage Bagger Stereo, arguably the experts in bagger stereo), he's starting using these over Hertz/Focal due to their performance and price point.
I have the JBL's running on my 6.5 Boom head unit only and running without an amp and I have a Klock Werks 14" Sports Flair and the speakers worked out perfect for me at this time. I will add an amp when I purchase my removable touring pack for my wife. I can hear my music going 70 to 80 all day long. Everybody has their own opinion on these but many are digging them just like me. Down below is the link to the thread that was posted awhile back. In the meantime I did a YouTube video on my YouTube channel and here is the link if you want an idea of what they sound like. Hope this helps.
Swomack
http://youtu.be/BZmWdW3sUTs
http://www.roadglide.org/53-audio/213353-jbl-gto638-6-5-inch-3-way-speakers.html
Cool... gonna check all these out. Thanks
Swomack
These?? If so, I can handle that price!
well, tried to upload screenshot but couldn't. Amazon has new pair of Jbl gto 638 3 way speakers for 55 bucks!
Here is all the information you will need for these speakers.
Product Description
Product Packaging: Standard Packaging
Product Description
GTO638 Hit the road with the big, rich, detailed sound that makes JBL® products famous. The GTO638 deploys the serious bass of a Plus One® woofer cone and an edge-driven My-Ti™ super tweeter that produces extended high frequencies, just as the best home audio speakers do. In the GTO638, you’ll find attention to detail rarely given to car audio. And it’s a game-changer. Select features to learn more: Patented Plus One® woofer cone Patented Plus One® woofer cone Our proprietary Plus One® woofer cone (patent number 7,548,631) is exceptionally stiff and lightweight and has up to 25 percent more active surface area than you’ll ever find on competing models of the same size. It delivers an audible increase in bass output and efficiency. Home theater-quality tweeter Home theater-quality tweeter The GTO683 has a high-bandwidth, edge-driven textile-dome tweeter with a large voice coil, just as high-end home audio loudspeakers do. The tweeter’s My-Ti™ (a proprietary Mylar®-titanium blend) alloy delivers great power handling, extended high frequencies and seamless integration with the woofer. True sound from built-in crossover network True sound from built-in crossover network By using a built-in crossover network with advanced high-pass and low-pass filters, the GTO638 creates a smooth transition between the woofer and tweeter. The result? Midrange vocals that sound so natural and lifelike, you’d think the vocalist was sitting in the passenger seat. Easy, patented Intermount III mounting system Easy, patented Intermount III mounting system The Intermount III (patent number 6,505,705) system makes installation easy. Using its JBL® installation rings (included), you can fit the GTO638 into factory-built installation locations varying from 6 to 6-3/4 inches. It even simplifies the replacing of aftermarket speakers. Can be safely driven by any head unit Can be safely driven by any head unit The GTO638 is compatible with aftermarket head units and factory-installed systems. Designed to replace factory-installed OEM (original-equipment manufacturer) speakers, the GTO638 is easily installed into nearly any factory-built 6-1/2-inch location – and doing it won’t require special tools or modifications. Genuine 4-ohm performance Genuine 4-ohm performance For the most powerful performance, the GTO638 makes the best use of any amplifier by providing an optimum 2-ohm load. It uses a lower-impedance voice coil than a typical speaker to extract the most power and performance possible from all amplifiers engineered to drive loads of 4 ohms or less. Outstanding audio output Outstanding audio output This muscular speaker offers 180 watts of peak power. Hit the gas and have fun. What's in the box: View contents What's in the box • (2) GTO638 speakers• (2) Mounting brackets• (2) Grilles• (2) Buffer for mounting bracket/grille• (4) Sets of speaker wire• (16) Screws• (1) Owner's Manual Download: Manuals & More Manuals & More Owner's Manual English: 1850.95KB PDF Warranty English: 286.3KB PDF
Amazon.com
The 6.5-inch GTO638 is a perfect replacement for those factory speakers, delivering smooth, accurate audio thanks to technologies like JBL's Plus One woofer cone, edge-driven mylar-titanium tweeter and supertweeter, and a built-in crossover network.
The GTO tweeter is both strong and light weight
while being adjustable
The Plus One woofer cone increases
Why JBL Sound?
For more than 60 years, JBL products have been bringing home the impact and excitement of the world's best recording studios, movie theaters and concert venues. Now, JBL engineers are creating these world-class listening experiences in the car. Thanks to advanced technology developed in the professional arena, JBL mobile products simply sound better than the competition. High output, superb bass response, long life and smooth response are all things you can expect from any speaker that wears the JBL badge. So join enthusiasts who know audio, and don't settle for anything but JBL in your vehicle. Bring the sound of the show on the road.
Listen Loud
The last thing you want to worry about is the quality of your speakers. We understand. All new JBL mobile products have to go through nearly 500 hours of environmental testing. We put them under temperatures fluctuating between -35° C and +90° C with up to 90 percent air humidity for more than 200 hours. We expose speakers to UV light for more than 150 hours to simulate a mounting location on a car's rear deck. We even shake things up, as all of our new mobile audio products have to pass extensive vibration testing before we release them for production. We've made unparalleled efforts to ensure the best possible quality so that you can listen long and loud when you crank up a JBL speaker.
Edge-Driven, Mylar-Titanium Super Tweeter
The JBL GTO638 uses a 1/2-inch (12-millimeter) Mylar-titanium (My-Ti) super tweeter with a large voice coil--much like a voice coil found in high-end home audio speakers. The benefit of the Mylar and titanium blend in making a tweeter is that it is lightweight and has remarkable strength. At the same time, its large voice coil increases power handling and reduces distortion at high output levels. This tweeter design also helps create more seamless integration with the woofer. The GTO638's tweeter is even adjustable, so you can modify it to optimize the sound. The result? Crystal-clear, extended high frequencies for true, high-end, audiophile-quality performance.
Edge-Driven, Mylar-Titanium Tweeter
For extra smooth and detailed sound, the JBL GTO638 speakers use a one-inch (25-millimeter), Mylar-titanium (My-Ti). The addition of this dedicated driver allows the GTO638s to deliver rich sound through the midrange frequencies where most of the vocals in music can be found. This extra detail in the midrange, paired with the �super� tweeter and woofer, means that the GTO638ss deliver true, audiophile-quality performance worthy of even the best home speaker.
Look for the True 4 ohm logo for the best real world performance
Intermount III makes installation into any factory location simple
Click to Enlarge
Built-in Crossover Networks
Typical entry level mobile loudspeakers use low performance bass blockers to keep bass from going to the tweeter. Well, the JBL GTO638 is not your typical entry-level loudspeaker. By using a built-in crossover network with advanced high and low pass filters, the GTO638 creates a smooth transition between the woofer and tweeter. The result? Midrange vocals that sound so natural and lifelike you think you the artist were right in the car with you.
Bass that Booms
Plus One Cone
The JBL GTO638 uses a 6-1/2-inch (160-millimeter) woofer with the patent-pending JBL Plus One cone technology. Plus One technology gives the GTO638 more cone surface than competing models of the same size--up to 30 percent more in many cases. With a larger cone area, the GTO638 speakers provide higher efficiency and better bass response. Add a low-Q woofer design for higher bass output from the typical mounting location and 180-watt peak power handling, and the GTO638 will really get your car booming.
Powerful Performance
True 4-Ohm Topology
Low-impedance speaker voice coils extract more power from your amp for more powerful performance than high-impedance coils do. JBL GTO638 speakers use a lower-impedance voice coil than a typical 4-ohm speaker to extract the most power possible from all amplifiers engineered to drive loads of 4 ohms or less. And the GTO638's are compatible with both aftermarket head units and factory-installed systems. Since many factory-installed systems incorporate 2-ohm speakers and include amplifiers designed to drive 2-ohm loads, replacing those reduced-impedance speakers with a typical 4-ohm model will reduce the power output from the amplifier. For the most powerful performance, the GTO638's make the best use of any amplifier by providing an optimum 2-ohm load.
An Easy Install
Intermount III (Patent Number 6,505,705) Mounting System
Doing it yourself? Installing GTO638 speakers in nearly any factory-built location is a breeze. Designed as replacements for factory-installed OEM speakers, they easily install into nearly any factory-built 6-1/2-inch location without requiring any special tools or modifications. To make installation even easier, the GTO638s use JBL's patented Intermount III mounting system. Depending on the vehicle, the factory-built 6-1/2-inch location can actually vary in size from 6 inches all the way up to 6-3/4 inches, thanks to the GTO638's included installation rings. Even if you are upgrading an older set of aftermarket speakers, the GTO638 makes replacing them easy.
And with such easy installation, you'll be listening to your new JBL speakers in no time at all.
$150 budget, I would go with Kappas or the DD. With a $200 budget Im still going with the Kappas. You have to plan ahead when dealing with audio. If you buy a set of speakers now for a stock system and then later add a amp, you want to make sure the speakers can handle it. The Kappas are very affordable and they are loud!
+1 on the Infinity Kappa line.
I found that if I tilt the tops of the front speakers back towards me a little, the sound is better. Just an idea to get all you can out of the speakers.
I was riding down the road one day adjusting the sound settings and leaned forward and sat up very straight looking around for something, the speakers sounded better. So my idea was hatched.
Discussion Starter #14
Swomack
It's either the gto638 or the Kappa 62.11i. Gtos are 55 a pair on Amazon and the kappas are 120. Just wonder if there is twice the difference like there is in the price? ?
if your never going to add an amp, the JBL's you listed will be fine. You mentioned using an amp in the future, the Kappas are best when used with an amp.
Discussion Starter #17
What amp install kit would be need if I ran the Rockford fosgate 300x2 amp?
RF sells their own install kit. They used to include an extra year warranty if you buy the install kit with the amp. Not sure if they still do it or not. Used to be about $30 on amazon.
If you want to piece it together all you need is some 10 gauge wire for power/ground and crimp on fittings to connect to the battery. Everything else can be done with crimp on butt/spade/bullet connectors if you don't want to solder. Will also need some speaker wire, 16 ga is fine for that. The 300x2 uses high level inputs so no need for a remote turn on wire.
Before you drink the kool aid from any vendor hawking their stuff as the best, check around the classifieds and audio sections of a few forums and see how many people are dumping that stuff after a year or less to upgrade to something actually worth that kind of money.
Discussion Starter #19
Swomack
Can you clarify if they are 2 or 4 ohm? I'm reading the description but one part says true 4 ohm then in specifications it says 2 ohm? Keep in mind I'm audio incompetent and sure I'm missing it
Just ordered a pair to replace my fairing speakers and that made me wonder if these would be acceptable to replace an RGU's Tour-pak speakers as well. I plan on eventually adding an amp down the line sometime, at which point I'd probably replace the rear speakers too.
I see the MoCo's "Boom! Tour-Pak Rear Speakers" on the H-D webstore are listed as 6.5", same as these, but I wanted to see if anyone had used these in their tour-pak yet or not. Thanks.
1 - 20 of 48 Posts
