1 - 9 of 9 Posts
What is a good aftermarket head for my 2012 RGC 103. I am looking for heads to compliment my streetable Andrews 57H, 2 into 1 pipe, and air cleaner.
You could look for a set of takeoffs on Ebay and then send them out to be ported to match your setup then resell yours to recoup some expense , I had Bean at http://www.bigboyzcycles.com/ do a set for my last bike and it worked out good , Bean has a reasonable price for a street port and is a very knowledgeable person .
Our long-proven Stage III Super-Tour Heads would work great.
9.8 cr
1.940" intakes
1.610" exhausts
AV&V guides
AV&V .650 lift springs
And as always, all of that work is done in house, as WE do not farm that out to other outfits, then call it our own once it comes back........
Scott
Stock heads work just fine save your money.
Stock heads work just fine if you have them ported. You can have them set up for the cams and compression you want, better option IMO than buying off the shelf aftermarket heads.
1 - 9 of 9 Posts
