I've run several sutotunes and still get a little pop between shifting lower gears.... particularly on hard acceleration. What is causing that..... the map or something else?
Banned
Typically your symptom is caused by a lean condition remedied by adding fuel to the decel enleanment table, however, sometimes it can happen from being too rich on the same table. I'd start by adding fuel in the decel enleanment table by adding maybe 10-15% more fuel there and try it. If that doesn't work, try adding more fuel. If that doesn't cure it, go the other direction and pull fuel out in the same table. Try this AFTER you've made sure that you don't have a simple exhaust leak that is sucking ambient air into the exhaust system. That can also cause the problem you're describing.
