1 - 17 of 17 Posts
Looking for a little help, yesterday I did an oil change. Switched from Harley Synthetic to Red Line Synthetic 20w50. Took it for a ride the motor felt extremely sluggish. Oil level was correct. Never felt right after it got to operating temperature. I ended up switching back to Screaming Eagle feels much better but not like normal. ANY IDEAS????
Never heard anything like this, following just because I'm curious. BTW, do you usually do your own maintenance, and confident at what you do?
Discussion Starter · #3 ·
Yes I have done the 3 previous services without issue, and I have installed all of the add ons. I found it quite odd / weird too.
I have been running Redline 20-60 in this bike for four years now , never an issue .. My first thought is you put way too much oil in there , was she smoking like a dope head ?
JtB
Discussion Starter · #6 ·
No smoking, I put a little over 3 quarts. The oil reads about half way on the criss-cross pattern on the dip stick.
I wonder if the valve in your oil filter malfunction.
Discussion Starter · #12 ·
No indicator lights came on, oil pressure stayed steady at 30psi while riding. I used Redline 20w50 vtwin synthetic.
The bike accelerated fine (or so it seemed) it was when I let off of the accelerator or shifted to a higher gear (5) there was an odd vibration at the center of the bike. When I pull the clutch lever in it idles fine and oil pressure seems normal. None of the indicator lights have been tripped, I pulled the plugs they look normal. I may replace them (they are almost 3 years old)
It could be me being overly cautious, but I would hate to do serious damage.
Again thanks for the help and suggestions.
Semper Fi
Discussion Starter · #17 ·
So I went into the diagnostic and checked the code. No thrown codes. Beginning to think it may be me being over cautious. Plan to ride it for a while and see what happens.
Thanks all for the help / suggestions!
1 - 17 of 17 Posts
