Probably something stupid, disconnected the battery to hook up my heated gloves cause it's brick in New York. Gloves worked great but I have zero power now on the bike, no lights nothing zero. Could it be a security thing? 2015 road glide. Need some help.....
power
Make sure you have all the wire lug rings on the battery terminals. One could have dropped down when you took them off.
Posting your problems in the Troubleshooting section would be recommended.
Check your battery connections again.
If you have no power check the main fuse which is under the left side cover.
If that is fine get the bike to the dealer, your bike has a warranty so use it.
The security system is not your problem.
+1 with Ironmark. If your gloves are directly connected to the battery you will have power to them, but no power to the bike, start with the main 50amp fuse (left side cover, can't miss it. Big and Red). power to the bike passes through it first from the battery.
