1 - 2 of 2 Posts
Had a strange occurrence on the 4th of July 2018. I turned the ignition switch on but when I turned the selector switch to run, my bike started! It did it it 3 times. Never happened before and today all was well. Not sure if outside temp (94°) was a factor. Need you all's input. Got it in October of '17. 1st time HD owner.
I would do a continuity check from the handle bar switches down to the connections at the bottom of the handle bars.
You may have a wire that is grounding out in the bars, or the start switch may be stuck.
1 - 2 of 2 Posts
