Anyone ever place in a 2015 to 2019 two Biketronics BT4180 Amps above and below one another in center front under Stock radio? If so care to share pics of it?
Have not read of two amps fitting in there yet. Have to be skinny and not have a heat problem. Most people put the second one in the saddlebag. I've seen a vertical mount for in the fairing. But don't know of anyone that has used it.
Man, I had enough trouble fittimg one BT 2180 with the BT bracket under the fairing of my 2015. I don't know how you would fit 2 under there without some serious mods, cutting, and fabrication.
I read your other post about the cubby holes. There's not much room in those at all. If I was going to try and do all this, I think I'd mount the amps in the tour pak if you have one.
Lil Chief
One BT 4180 amp is awesome, but two....WTF...keep is posted with pixs..
