1 - 12 of 12 Posts
Will these change length adding/dumping air? If so how much up down?
I have a pair of the same, no the height doesn't change, it just gets stiffer, same as stock, you just have a little less travel. The advantage of these shocks over a lowering kit is if you bottom out, the tire won't hit the fender or rub the wires in the fender, plus the geometry of the bike doesn't change.
Sent from my SPH-L710
PM sent.
1 - 12 of 12 Posts
