Howdy y'all. I am new here and think this is a great source for the Road Glide devoted.
I have a question about bleeding/flushing brake lines. I have a Mity Vac and was using it to bleed my brakes the other day. After reading the instructions I was ready to go. Well when I put a vacuum on the bleeder and cracked it open I only saw a small trickle of fluid come out the hose and the master cylinder drained very slowly. Shouldn't I see the hose fill with fluid? Shouldn't the master cylinder drain rather quickly? The lever feels good and the bike stops fine I am just a little nervous about what I have seen here. I am a car mechanic and an aircraft mechanic and past experience with bleeding brakes tells me my drain hose should be full. I have replaced my front pads, rotors (they were warped and locked the front brakes whilst riding), flushed out my calipers and lines, and cleaned the Pistons on the calipers. I also cleaned and rebuilt my master cylinder. I used new DOT 4 fluid and made sure there was not trash in the system that may block any passages. I also bled from the banjo bolt at the master cylinder as well. So what do y'all think?
