1 - 12 of 12 Posts
I installed VIEDs on the O2 sensors which involved adding a ground wire to the negative battery terminal and adding a ground on the brace between the front frame down tubes. Now my ABS light is blinking. I'm an old Shovelhead , EVO, Carburetor guy so I have a lot to learn about Fuel injection, ABS, Sensors etc. Any thoughts or advise appreciated. Thank you
What was the ground on the frame tube for? My FL - vied-10 only grounded to the battery.
What year bike ?
I may have asked the question too soon - I haven't been able to ride it yet so maybe there is no problem - the Vieds I have plug into the oxygen sensors then back to the wire harness - they both have a ground wire and the instructions say 2009 and newer need to be grounded - thank you for your replies - It's 22 here today so I won't be riding it for a while
On my 10, when you first start the bike the ABS light always flashes (slowly) until you start moving.
I'll take it for a ride and post the results . I need to get an owners manual for it - It's a 2009 RG CVO. Thank you for the help!
well you guys were right - the only thing wrong with my bike is the nut that holds the handlebars - I've only had the bike a couple weeks so I have a lot to learn. I appreciate your kind responses very much.
Been there, done that ... I went from an 87 FLHTP that I'd had for 20 years to a 10 TC that I couldn't lower the idle on (WTF?!?). The first time the 10 decided to glitch on me...I bought an 81 Shovelhead FLTC, that I knew I could depend on..:grin:
Reactions: fitscott
Don't feel bad, that had me too first time I sat on my ABS Glide...
I still a 1987 FLH with a S&S V111 and I love it but my 2009 RG is extremely nice - My Brother is getting my 87 so we can keep it in the family.
Welcome to the tank, yep the 09 CVO beasties are the best. The ABS light stops blinking once you 're above 5 mph (I think) but it's in the handbook with the beastie..
1 - 12 of 12 Posts
