I installed the jl audio hx280/4 amp (Bridged) and an LOC on my 15. I had the dealer flash and it made a world of difference.
My question is: has anyone had an issue with what is best explained as "blowing the tweeters" of the speakers? They just started to sound muffled. I have had this happen twice now. Once on a set of Morel ultra integra 6.5 and now on a set of Hertz mpx 6.5.
Jcalvinm: I run that amp with the biketronics line leveler and there titan II speakers and have not had a problem.i think shark nose is right to much power to those speakers,I think the line leveler cleans the signal better than the flash. I hope your speaker vendors are making things good.if you bought on amazon you should be O.K. titan II are waterproof and guaranteed for life 179.00 made by Hybrid audio technology
Thanks guys, the speaker vendors are taking care of me luckily. I am also going the BT-355 route and forgoing the flash and the line out converter i was using. I really hope that does the trick and I don't ruin another set of speakers!
JL amps are very efficient! you are pushing a true 140 watts to each channle.my gains are set just under 1/2 so far so good.good luck!
Yup! JL hx 280/4 is a powerful little amp.I have it running a pair of 6.5s I bet it could drive lowers. when I do them.not sure how I would wire them. Some day.
