So, beautiful fall day for a ride here in New England. Sunny, in the 80's, leaves starting to show some beautiful colors. After a couple hundred miles, while descending a large hill, my son in law tells me he see's blue smoke puff out of my right side exhaust pipe. This has me a little concerned. Bike ('13 ultra) has run excellent, never beat on, just under 7K on the clock. Oil level good, no oily soot in tailpipe. Plugs also look good. Just a fluke or the beginning of a potential problem. Still got a few months left on warranty. What else might I lean towards, or just don't give it a 2nd thought.
Could have been an oil bugger going down the intake if your head breathers are routed to the backing plate.
Mine is starting to do that too according those that follow me. I'm at 18,000 miles. Tried an oil/filter change even though I do both at 3500 miles and Amsoil 20/50 & HD filters but it still smokes when hot.
The problem you are describing is usually associated with leaking valve seals. When descending a hill your throttle is closed for an extended period of time with engine RPM's usually at or above 2500. This causes a very high vacuum in the engine and will pull oil around the valve seals and into the combustion chamber.
