I tend to ride relatively fast as compared to the speed limit. Like some others, I use a radar detector. Has anyone tried to connect a bluetooth radar detector to the new Boom audio systems? If so, how did it work? What equipment did you use? Were the protocals supported?
Having read all the Harley literature I could find, it appears that the only Bluetooth device that will pair with the BOOM system is a smartphone.
I've found the info system will find a pair with the Sena but since it will not send a signal back to it, it won't work. The radar detector, if it is compatible should be just sending a signal to the radio and would work it would seem. Interested in what you find out.
Discussion Starter · #4 ·
I guess I going to have to buy another radar detector.
