1 - 2 of 2 Posts
I rode to Destin last week and I noticed when I would start going up hills the motor would bog, I already replaced the fuel filter. I noticed when it bogged my timing would go real low to about 8°. I put some chevron fuel injector cleaner in that seamed to help but on the next tank it started again.
Well, your information is not real clear, and you didn't ask any questions. How do you know what your timing is? The bike is always going to need some additional power when climbing hills, right? You are not lugging the engine, right? What happens when you downshift to a lower gear? Do the rpms go up when you give it more throttle? Is your air cleaner clean? Did you get some bad gas? Did someone overfill with oil?
1 - 2 of 2 Posts
