1 - 16 of 16 Posts
Complete speakers and two amps out of CVO Roadglide stage 2!
SOLD SOLD SOLD
$575
SOLD SOLD SOLD
Sent from my SM-N960U using Tapatalk
One amp four speakers that was amp in fairing!
I've got the stage two in mine with those same fairing speakers. One amp per set of speakers. Should have been an amp in a saddlebag then. Normally the left side. Mine with the S2 has two amps, one in the fairing and one under the tourpack (which I installed). Those amps are 300 watts each. Your bike came with a 600 watt system. Something isn't adding up Unless they changed the amp to a 600 watt amp which I have heard nothing about since the '18 was introduced almost 18 months ago.
Here's a few link to the parts fiche from Ronnies HD.
saddlebag http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?Type=13&make=hdmc&a=1233&b=6&c=42&d=2018 Harley Davidson Street Bike FLTRXSE CVO ROAD GLIDE (TC)
fairing http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?Type=13&make=hdmc&a=1233&b=5&c=0&d=2018 FLTRXSE CVO ROAD GLIDE (TC) SOUND SYSTEM - 1
Thank you I will check with shop today!
I hope like hell they didn't "forget about it on the bench" and didn't return it to you. You can also go look in your left saddlebag and see if it's still there. You should have an extra hole in that bag and a harness going into it.
Sent from my XT1710-02 using Tapatalk
Hertz and arc audio sound is fantastic! Very happy with it! Thank you again!
Discussion Starter #14
Sorry but I don't want to split it up!
1 - 16 of 16 Posts
