1 - 4 of 4 Posts
Is it worth using the Harley Boom Audio Bass Booster Tour-Pak Port Kit with the J&M speakers?
JMJOHN
absolutely ,,,, we just recently used it on our own Road Glide Ultra with the J&M 8-speaker, 500w system ,,, and Harley's porting piece into the trunk from the pod speakers works very well ,,,,,
I'd say yes. I installed the ports on Hester with HogTunes speakers and there is a noticeable difference. Good bass reproduction is about the movement of air and you really can feel the air move in the Tour Pak.
One word of caution. I have the HogTunes rear speaker pods and the plastic is apparently thicker than the HD ones because the depth of the cylinder was insufficient to use the rubber rings. Easy to work around, but nice to know if you have these speaker pods and plan on installing the Boom! ports.
1 - 4 of 4 Posts
