1 - 2 of 2 Posts
Put some 14” KST Spearheads on 2019 and everything fit without extensions, however I want to replace factory lines with with braided lines. I done many brake jobs no problem with bleeding brakes. My question is after removing the lines with the abs system is there something that has to be done differently?
Keep the air out of that ABS pump and you'll be alright. There's tools out there to cycle the pump if you either want to flush it also or need to bleed it.
1 - 2 of 2 Posts
