1 - 12 of 12 Posts
Just in stalled khromewerks 2 + 2 sweeper bars on my 12 road glide ultra, went good with a lot of help from threads on this forum. My only problem is now my brake lights are on all the time, i know its in the front brake switch, but i dont know how to fix, and I'm sure someone out there does, please help. Thank you
Did you check the little tab on the switch and make sure you didn't break it? It's extremely easy to break. :(
Discussion Starter · #3 ·
It's like the brake lever is not making contact with the switch, if i push on the brake lever the lights go off
I had that happen once, I had the bushing on the wrong side of the lever.
If you pull the lever in and the lights go out, I wonder if those two wires got crossed when you did the bars, and they might be backwards?
Discussion Starter · #7 ·
After researching it a little, i did not shim the brake lever so i bet i have broken the switch, now the next question is how do i fix it?
Pull the switch and solder in a new one if it is broke. Do a search on here, I have read where some have drilled the lever and put in a small screw in the tab of the lever to take up the distance. Myself I would pull the housing and have a look, if you are lucky you may have put it in a bind by not spacing the break lever during the install.
I've broke that switch before, I opted for the small screw solution since HD wanted $60 for the switch. I found the switch on ebay for about $15 and ordered it, (Drag Specialties), but the screw is still working. That was 2 years ago.
I was lucky enough to find the piece that broke off. Put a short piece of wire in the center and super glued it and the piece back on. Still working 15K miles later.
Discussion Starter · #12 ·
Will fix eventually, but for right now just stuck a piece of rubber to the brake lever and it is working, getting ready to take out for a test ride
1 - 12 of 12 Posts
