1 - 4 of 4 Posts
I tried searching but didn't find the specific answer I'm looking for so I apologize in advance if this has been answered elsewhere.
With -2 monotubes installed, how do te front brake lines sit? I notice that at stock height, there seems to be quite a bit of slack. When the front end is lowered, it would seem there would be an excess of brake line.
Anyone have any insight on this or possible solutions? I know many ppl use te monotubes so I'm sure this is a common issue.
I was looking at buying the magnum shielding lower brake assembly but don't want to if it will be too long.
Thanks in advance.
I have extra slack in mine after the -2 drop. From the calipers to the T block. Isnt really causing any issues though. Guess the only way around it is to have custom lines made up.
Even with the 2" drop, I think the fork tube stops that limit the full extension remain the same. Although rare it is still possible to get maximum extension which would require stock length brake lines.
1 - 4 of 4 Posts
