Whatever is turning that rotor cheery in your avatarWho makes the best pads for our Heavy beasts? I have replaced with Harley's several times. Are there any that last longer?
I would imagine it would not have any ill affects. Cars and trucks sometimes have different pad materials and most are ABS nowa days. ABS detects different wheel speeds and compensatesI can tell/feel the confidence on sinister on back &
Organics on front (03 flt) from the stocks on flh (99)
all components equal
So gotta ask...about ABS or even linked WOULD they care
If there were different pads Front & Back?
that...is darn impressive, you must not live in the city, that's a lot of miles on brake pads.:nerd:First set went 50,000 miles.
Yes live in the country. From driving a large truck for work learned to look way ahead, anticipate stops/slowdowns. Some charge right up to a stop sign and hit the brakes hard, I do the opposite. I ride the dragon fairly often, the cadence of slowing into a curve, powering out of the curve let's one keep a fairly robust speed without smoking the brakes. My RG will never be a sport bike no matter how hard it's pushed. :smile:that...is darn impressive, you must not live in the city, that's a lot of miles on brake pads.:nerd:
One of those sets comes with new pins or something like that to jack up the price. Same pads though.How do the Lyndall and other sintered metal pads affect rotor wear? Do they increase heat which can cause warping? I've used EBC kevlar/organic pads in the past with good results. I'm really not sure what to use on my 2015. All of the aftermarket pads use the same pad for front and rear but Harley uses different part numbers. It could be the compound, an indicator mark or even packaging. I want the best pad I can get but I'll default to OEM if I can't find something better.
That is correct....all the same two part #s on all the pads for piston sides and non-piston sides. The rear kit is a different part # because it includes the grease and grease template, thus the slight price increase. I'm not sure WHY the MOCO determined that the front kits don't require the grease & template.One of those sets comes with new pins or something like that to jack up the price. Same pads though.
