1 - 1 of 1 Posts
Shark of the Month October 13
For those of you with ABS that have switched to a 21" or larger front wheel,
and you switched to a single rotor from the factory dual setup:
1. I take it the ABS gets all of it's info from just one sensor on the left hand side so going to a single sided bake system doesn't affect it at all?
2. Anyone seen any actual test data that compares the dual 11.8" brake set up with a single sided 13"? Significant braking distance difference or not? I like the look but don't want to give up any significant margin of safety.
Thanks in advance for your reply.
1 - 1 of 1 Posts
