After sifting through all of the parts, organizing, cleaning, organizing, cleaning, I eventually started to sort things out. As this is my first Harley (see intro page under my user name), I began to do copious amounts of research into discovering what was what and which parts belonged to which year, make and model.
What I found were a couple of goodies...First, bar and riser combo on the bike were ~14in. Bung King brand.
I don't have a photo of it, but the intake manifold has a small CNC'd, what looks like block off piece, that has HPI branding on it. The guts don't look like anything special (ported, polished, etc.), but then again, this is my first Harley so what do I know lol.
The front wheel is a 19in. enforcer wheel - I'm definitely a fan!
The rear wheel however is a mystery...I'll be sure to take a picture and maybe someone can help a brotha out.
I purchased it without knowing if it ran, but I'm confident it will. The motor turns over manually without any funky-ness.
Although I found some nice tid-bits, I also found some unsavory-type shadetree mechanic work...:
Yep, you saw correctly, wiring for the voltage regulator - twisted together and wrapped in electrical tape...
If you know what you're looking at, you might not be concerned because you'd know that that voltage regulator is not stock on an 08' touring model, but I didn't know that at the time and this scared the dickens outta me. I figured this must be the first sign of worse problems to come. Luckily, I haven't found anything world ending, just some sketchiness.
