More progress! (Tortoise like & just as boring, but progress nonetheless).
Tldr: I fixed a bunch of wiring/lights & installed a new ignition switch! Pictures below... Lol
I spent some time yesterday and today testing the wiring that I had done so far; verifying that with the bike as a standalone unit that everything worked.
Aaand, my right turn signal had no running light function. Turned out to be the bulb. I ordered a new set and replaced both. Front turn signals, check, right?
Not so fast! When I would wiggle the connector for the turn signal, I began to get intermittent light. Haven't dug into that yet as I got distracted, but it's probably just a bent pin.
As for the function of the turn signals, when I would cycle them, they would blink correctly three times and then would hyperflash...back to the wiring diagram. My idiot lights must be off of another bike because the roadglide diagram shows r-turn/l-turn & high beam sharing a common ground. De-pinned the connectors, re-arranged the wires according to the diagram & whaddya know? They function as they're supposed to!
**^This fix also fixed the lit 'Spot' button on my dash that wasn't lighting up. It draws power from the low beam circuit.
My headlights weren't coming on correctly either. They were winking when I would toggle the high/low- low beam would only work on the right and when you hit the switch only the high beam on the left would turn on. Double checked the wiring diagram, turned out I had a couple wires in the wrong order. Fixed it and now they work.
Now for the best part:
A guy I follow on Instagram performed this mod where he relocated an 80's Harley ignition switch to where the cigarette lighter normally is. I thought it was really slick and have been planning on doing it for some time. Well, I finally got around to it! It's a really neat solution and it's not like I was ever really going to use that lighter anyways... Any accessories I add to the bike will be added on proper-like & ran to the fuse box.
P.S. I ordered new led bulbs for the indicator lights as the Neutral one was out. If I'm gonna replace one, may as well upgrade em' all.
I think that's all...picture time!
Sent from my SM-G965U using Tapatalk
