1 - 20 of 23 Posts
I just watched the J&P video of the cams install and feel pretty comfortable doing the job myself. Other than the speciality tools and plate for the cam bearings and the gauge needed to check run out I have everything needed. Who here has done their own and are there any issues that arise that I should know before I do this? I'll probably bite the bullet and do this swap this coming winter.
I was thinking about doing my own to, but I looked up those tools and the cam bearing/install tools are about $300.00, I think I'll have a good shop do mine, they have to feed thier kids to. I love doing my own work but with the cost of the tools which I won't use at all I'll let a pro do it. I'll do the monotubes and figure out which 21" wheel I want.
A friend of mine bought the tools off of ebay for about $130 shipped. Then I purchased a cam locking tool and lifter holders for $40. We have changed cams in his bike and mine with no issues. Only thing I wish I had done, was buy new lifters.
My cams are on the truck, scheduled for delivery today. I'll be doing the install on Saturday.
One of the members here, X in Black, has a set of the tools that he's willing to rent for a very reasonable price. They should be here today or tomorrow as well.
Cheers. -Jay
Got a quote for 1400.00 for cams, lifters, dyno tune. They get about 400.00 for labor. I can live with that. I'm sure the'll do a good job. I'm not so sure of my confedense on doing it myself. What cams are you goin with?
I had a quote from an Indy here for $1200 for cams, rods and lifters. Tune wasn't included in that. And he really wanted to push the parts that he sells.
I've watched every video out there and I now have a high degree of confidence that I can do it myself and likely have better results.
I'm going with Woods TW-222 cams, Woods directional lifters, and Fuelmoto pushrods. All tolled, I'm saving 500 bucks. If you count the fact that I won't need a dyno tune (FM sent me a known good PV map for this setup), I'm even farther ahead!
My thought process is this. I'm installing a Dragos pipe and thunder max with Drago tune. As long as I get cams that Frank is familiar with I should just need to get a new base tune from him and let the auto tune do the rest. Hell, with the deal I got from him on the pipe and tuner ill likely get cams from him as well. I understand that bike mechanics need to feed their families but I also like to get to know my ride better by wrenching on it myself.
I did mine myself. It's easy. I've got the bearing removal and install tools if'n you need em! You can save a ton of money doing it yourself. It's an easy job!
btw....The cam lock and lifter removal tools are not necessary for this job. Save you a few more bucks!
Just be real aware of the push rod tpi and what the manufacturer of the lifer recommends for adjustment. If you are running chain drive, don't worry so much about run out. When running gear drives, then worry about it and believe me, you will know when youhave run out issues with gear drives. Good Luck. OH and take a look at Goerges Garage, that is where I bout my cam bearing install and removal tool. Hope this helps.
Tonight, it's Friday Night Steak night at my house:
But tomorrow morning, it's all about installing cams:
Complete with instructional tools:
Nice looking steaks! I hope the big ones yours. Good luck with the install. Keith
Nice. Let us know how it goes. I'm getting antsy about doing mine. I spoke with frank and since I have to wait awhile for the pipe anyway I have some time to make a decision.
Discussion Starter #15
A couple. First I have to convince myself to dig into my two month old motor with 3000 miles. I would hate myself if something went wrong (cam related or not) and I had an issue with warranty. Second, which cams to get. Frank recommends the Tman 555, zippers 575 and the Dragos 501. I'm gonna do some research on them and others.
Cam, lifter, and pushrod swaps are not that hard. Don't forget to budget for a bolt cutter for the stock pushrods if your going to adjustables.
Double and triple check the snap ring installation on that front cam.
The sharper edge of the ring should face outward.
Take your time, use good assembly lube and double-triple check the rear and front cam alignment too... take a picture even... If you forget to double check, even tho you are 99% positive of alignment on the bench, you'll wake up in the night and second guess. I know I did and it's not my first goat rodeo...
If you need help, I did a pretty intense build thread on a different forum that explains things well.. Check out the RS 557 as well, that is a great cam and I am using it now. :D Makes a lot of power. Let me know if you want the link to that build thread or not, it will help.:cool:
Discussion Starter #19
I would like to check out your thread. Thanks to everyone for the advise and encouragement! I'm gonna wait till frank gets pipes in and ready to ship before I make my final decision but I am def leaning toward doing it. Everything was pretty strait forward in the J&P video but it still makes me a little nervous to dig into the internals on a brand new bike.
1 - 20 of 23 Posts
