1 - 9 of 9 Posts
I have a 13 roadglide. 8,000 miles I would like to swap cams. Thinking woods 777. Are lifters required?
not required. but based on my experience, if they're the OEM lifters, you will have issues on down the road with that high lift of a cam. I had to replace mine with in a couple thousand of installing tman 600 cams.
I am putting Fueling 574 cams in my glide this winter,never had any issues with the stock lifters in the 20,000 miles but i will be replacing with Fueling lifters at cam swap.With the aggressive ramps on most woods cams new lifters wood be a wise decision.
Replace lifters when you replace cams, your right there anyway.
Ya. I changed cams. Then about 5000 miles later did the lifters. Wish I'd done at the same time.
FWIW, that cam's intake closing number wants at/very near 10.4 cr to optimize it's potential and delivery, and your OE 103"(?) is sitting about 1 full point shy of that at 9.6 cr, but that said, we'd reccomend to change out those "Made in Mexico" lifters to an S&S lifter.:)
Scott
Scott
A polite way of saying that your stock motor with 777 is going to suck below 3000 rpm
1 - 9 of 9 Posts
