1 - 14 of 14 Posts
By the looks of most dyno results the stage 4 kit only gets on average about another 5-10hp and Tq (if the intake and exhaust has been done). So my question is why spend all that extra money for a stage 4 when it looks like cams are very close to the same performance, or am I missing something. I know all dyno's are different so that is probably part of it, but is was thinking stage 4 and now I am rethinking it. Any input is welcome. Txs
Your right stage IV builds don't give you that much more bang for the buck. A good cam, exhaust and intake upgrade with a good EFI tuner and a dyno will give you all you really need for a good rideable touring bike.
If that's all a stage 4 will net you then yes, add cams, intake, exhaust, tuner, and maybe some headwork, and you can gain a lot more than that.
Fuel Moto's 107 kit appears to give numbers close to 120R motors with cams intake and exhaust. Check out their stuff yet? I would really be considering that if I was in that market. I may go that route after I ride the piss out of my Stage 2 with SE255 cams. Bike runs hard and fantastic with the SE tuner and a dyno tune so will run this for a few more years.
I havent heard or seen many intriguing stage 4 kits done on this forum or in person, atleast not the harley one.
Very straightforward to establish north of 120/120 with a 107".
We were doing that on S&S 107" engines loooooooong before these messages boards were invented.:)
Scott
Stage 4
Used tman 590 cams instead of SE cams .
Although the SE 259 does pretty well also .
If your stage 2 ( just cams ) does 93 /110 that's 20 hp less and 10 tq less .
Big difference
Exhaust, Intake,Tuner, Cams and tune will really give you a good bang for the Buck and you can do it in phases to help on cashflow
If you have the funds, I would go the 107 route before going the HD stage 4
IMO The 107 build seems to offer a better bang for the buck than the Stage 4
BTW...my opinion and $5 will get you coffee at Starbucks ;)
After stage1 77 hp 88tq. SERT V/H high output 2 into 1 pipe and new air intake. Stage4 121 hp 118tq. Same tuner, same pipe. I did change the air intake. For me it was worth it. I wanted a bike that I could pass with and get back to cruising (with the wife).
Harley Stage 4 kit is the most unreliable kit for numbers have I have seen.. I have seen 106 to 120 on dyno sheets for those kits.. I can get over 100 with cams, pipes, air, tuner and a .030 head gasket. If you are going to do anything go with a 107 from:
Fuelmoto, Frank or Hillside
These guys all know their business and offer the best kits with the most consistant dynos out there.
I'd have a really hard time cracking open a good solid 103" motor just to add 4 cubic inches. Heads, and the right cams with the correct compression will gain you much more than the 4 cubic inches.
The Harley "stage" builds are all pretty conservative and generic.
I keep waiting for something to die in the bottom end of my motor so I have an excuse to build a big inch touring motor.
You say that only because u haven't ride it. Between 35 to 50% increase in power. It changes the ride completely. Now I can see the other side if it is not broke don't fix it. But I did mine with 3k miles lol. I would do it again In a heartbeat
I did the stage 4 kit on my 2010, and it is plentiful of power. I hardly ever get to twist the throttle all the way back because nobody around here can hang with me as it is. I am, however, considering selling my motor, and going with the 120R. Then dropping another 2-3 in to have it built out as well. But at that point it basically becomes a rocket. So you have to ask yourself, when will you really need all that power. But either way. To give an opinion, IM glad I went with the Stage 4, and Im glad I had the dealership install it. I have had no issues with it since it was installed, and it still gets decent mileage, and enough power to make me satisfied for now.
That dyno sheet says MVA heads ?...do they come in a stage 4 kit now ? I had a stage 4 kit in my 13 RGC . I was happy ! But then got a 14 SGS and added dresser duals, AC and PC5 ( stage1 ) basically.......seat of the pants I can't tell much difference, maybe at high RPMs......both top out at 122 - 125 mph. When I do something more to this ....it will,be Dragos or Fuel moto...I live in the mid west.
1 - 14 of 14 Posts
