I have a 2018 RG Special. It cam originally with a 107. I did the stage IV kit at HD and it converts it to a 114. The kit includes CNC Ported Heads, Performance Valve Springs, 64mm Throttle Body, High Flow injectors (5.5g/s), 4.075" bolt on cylinders, Forged 11:1 compression Aluminum Coated Pistons and rings, SE8-515 cam, Cam bearing upgrade,High Performance tappets, High Capacity Clutch Springs and disks (1200N). I also added V&H Headers with V&H 4.5 Power Duals. This is all tuned up with a TTS tuner. My numbers are descent on Dyno 120hp 114 tq. I want to increase my torque. I am looking at T-man 216 vs Woods 22XE. I would appreciate any advise and suggestions.
