1 - 10 of 10 Posts
Currently running thunder header & K&N intake & Arlen ness cheap chop fuel tuner. Thinking about cams. What u recommend?
It all depends what you want. Do you want more low end torque? Mid range torque? High end? Each cam is designed for a different purpose. A good all around cam is the SE255.
I am runnin Headquarters
575's and couldn't be happier. Two of my buddy's are runnin the 525's on 96 in motors
Amd are happy with theirs.
Rowdy
Sent from my IPhone cuz I am out end about.
Rowdy
I think honestly the tw 555 from Woods would really really make ur bike awsome. Put a set in for a buddy that made 90 hp and 99 ft lbs with a 96, D&D with stage one. Walks all over my other buddys 103 with the se 255s
I really like the se255 cams I had on my 103" roadking. Good torque through bottom and midrange.
Sent from my Droid using Tapatalk
Have 103 with 255's can still use OEM solid push rods.
Good pull from 2300-4300. Awesome 2 up cam, no downshift to pass or climb hills fully loaded.
1 - 10 of 10 Posts
