1 - 18 of 18 Posts
Was looking to add a little more light to the rear end of the bike so finally got to work on it. Added red LED accent lights between the bas & fender and installed an LED run/brake light to the back of the passenger backrest. The accent lights are from Autozone and tapped into the run light wiring.
The run/brake light is from Autozone too and is a semi trailer light. I built a harness and connector to plug into the bike connector for the tour pak lighting. Fabricated my own bracket to mount it and powdercoated it gloss black. I had hoped the bar for the backrest was hollow and I could run the wiring internally but no such luck (then again it wouldn't be as strong as it is if that were the case)! ran the wiring down the right side and zip-tied it to keep it secure.
All in all was about a $59 mod plus my time to get it all done......
Running lights........
STOP!! lights......
My eyes are bleeding! lol
Man, if that doesn't get you noticed, nothing will! Good job on achieving your goal with a little ingenuity and without spending big bucks.
Holy fu##-me-running. It's only a picture and that is bright as all get-out.
The biggest thing I was trying to accomplish is getting some light up closer to eye-level for anyone behind me when I have the backrest on!
Wow! That looks pretty awesome. Looks like a BAL alternative to those of us without the square tail light and at a fraction of the price!
Great job!
You left off one word off the end of your thread title, the one that starts with A and ends with Hole!
Ingenious!
Man I'd be afraid a Boeing 747 would take that for a landing field ;)
Grats to you for getting it done for that price and making it functional!
Great job. Those are solid bars instead of tubing???????
I started drilling straight into the end of the right arm and made it in about 1 1/2" and it was still solid so I stopped. FIlled it in with JB weld and black touch-up paint.
Innovative - looks good............
I real like what you did with that light. I did not want to drill any holes in my back rest. Or have a piece of steel to use. So I took a few round head bolts a grinded off most of the head tell it was real flat. I then used a few washers to have it grab the edge of back rest support. I brought the LED light at Wal-Mart painted it black on the outer edge as it was white. I did leave the inside white to reflect the light better. It is a high mount break light at the moment might change it to a run/brake light later.
Looks good, and bright enough to hopefully catch the attention of those texting also.....
Discussion Starter #18
1 - 18 of 18 Posts
