1 - 10 of 10 Posts
well i'll make it short the bike dies around 70 mph. i shake it side to side and it turns back on. i think the filter may be getting plugged. what do u think
Either gas filter or hi-speed jet/small circuits in carb would be my guess.
If its not obviously the filter (after inspecting), I'd add a heavy dose of Sea-Foam gas additive . That be the easiest & cheapest next step.
You should be able to eliminate the 70mph. If its a jet it should do it all the time, just throttling. Same with the float, unless the float is hanging, causing a low level in the bowl, causing you to run out of fuel. Does the bike just cut out all at once, or is there sputter then dies? Are you sure its fuel related? You 'shake' it side to side after your stopped, then it fires right back up?
thanks for the replies. yeah it just falls on its face(sputters a lil) i pull the clutch in shake it side to side let clutch out and she comes back to life. i have only noticed it when im down to about 1/4 tank of fuel. i have an aftermarket(CHEAP) fuel petcock on it. when i got the bike in august'10 it had sat with a full tank of fuel since 2004. i cleaned the tank,carb, replaced the fuel lines. the last time i took the filter out it had flakes of crap on it at the base of the filter im thinking that may be the case again. or i screwed up the fuel gauge and i really have less fuel than i think. thanks again for ur info.
Check your crossover and see if something is partially blocking it. You can also pull your petcock and check the screen for any debris. If you have debris then there's a good chance you have a blockage in the crossover. It sounds like a fuel problem.
Drop the bowl and see if anything is in there. If so,....pull each jet and clean it out. Matter of fact,....even if there isn't anything floating in the bowl go ahead and pull the jets and clean them. While it's off, put some sea foam in a spray bottle and spray down the float mechanism and move the float up and down. Do this a few times.
Also drop the petcock and clean it off
If the bike been sitting since 04 the carb is probably going to need a rebuild kit to be perfect. Was there gas in it or did the gas evaporate? Did the tank have that spoiled gas smell ? What Carb is on the bike ? It's not rocket science to rebuild them. It could be suckin air in through the intake seals also. Give it the old carb spray WD 40 test and see if the Idle chances. Do it right the first time and ride on!
well i removed the cross over line and rust flakes came out of the hose. so i removed the filter and it had rust crap on it also so i cleaned that to and removed the tank and flushed it also. put it back together and so far so good.
thanks 4 all the feed back
1 - 10 of 10 Posts
