1 - 3 of 3 Posts
Is anyone else having a problem with this? It seems that when I hit bumps I will lose my CarPlay and have to open the glove box door pull the cable and put it back in to get it to come back. It’s pretty annoying. I’ve tried different cables and had the same result.
Sounds like the USB cable is loose at the HU end. If it is to fix it you need to remove your outer fairing and unplug and plug back in the cable. Looking at the HU it is the cable on the far left.
I had to do this to mine after upgrading my amp as I didn’t plug it in tightly.
I’ve been having the same problem. Some days are better then others. I ended up using Bluetooth last week it was so bad. I’ll try to replug it as well.
1 - 3 of 3 Posts
