1 - 10 of 10 Posts
Riders,
What does removing the cats do, does it throw a code? Pro-con. I removed my baffles, will removing cats make it noticeably improved ?
You will lose a lot of low end torque running wide open pipes.
Put the baffles back in and take the cats out . I drilled mine out , others have it cut open and removed and welded back up ..
No codes , sounds 'like it's supposed to' according to my spousal unit , doesn't feel choked down all the time , runs cooler .
I gained 386.74598 ft lbs of torque at 174859.652315 rpm and 350 hp at 164581.602658 rpm .. :surprise:
JtB
I replaced my head pipes with Power duals, no lights..I just called V&H, got the new numbers..
1 - 10 of 10 Posts
