……. Second item, the fender. The fender was bare metal and my painter doesn’t want to mess with it til winter. In the meantime, MN has been super humid and it started to show surface rust already so in the spirit of not wanting to be down for an extended period of time, I’ve decided to paint it myself. Be clear, I am not a painter and I don’t expect that it’s going to turn out super great but it’ll be painted and cleared and protected from the elements for the next few months of riding that we still have left up here. It’ll look perfect from 50 feet away. I’ll post up a pic when I’m done and have it all back together.
I purchased the Color Rite rattle can kit and the color coat was a perfect match to my brilliant silver pearl which is a very difficult color to match. My son also used it in the HD vivid black, and it too was a perfect match…….
That said, their primer and color coat is very good, but their clear cost is absolute ass. Both of us followed Color Rites instructions to the letter, but, after two attempts each, sanding off the color and starting over in between, the clear still failed. It covers very spotty and leaves a very rough and grainy texture that you can’t buff out. It really is horrible. We both ended up repainting a third time with the Color Rite paint, but went back with K2 Gloss Glamor clear coat instead, and the results came out excellent….. In deciding on the K2 we read tons of reviews on-line, and pretty much everyone said the Color Rite clear sucked….
You might be surprised how well a DIY spray can come out; we were. As you probably already know, it’s all in the prep; sanding, primer, sanding, first coat of color, sanding, clear, cut and buff, etc. We ended up at 3 coats of color and 2 coats of clear and it took all day. Light coat, let dry, light sand, wipe with alcohol, repeat….. Then let it sit for 48-72 hours before doing the final cut and polish.…. We also made a makeshift paint booth with 1 X 2 furring strips and plastic sheeting which really helped to keep the dust and airborne contaminants at bay…….
Spraying the color and all the prep work and sanding wasn’t that tough, and the K2 was excellent. The other option to consider is if you know someone with a paint sprayer that knows how to use it, have them lay down the clear coat and you can buy K2 in a can for that… Getting the clear right will make or break your job….. Good luck, and like I said don’t cut yourself short and you might be surprised how well it comes out…..
Spray Max USC 2k High Gloss Clearcoat Aerosol
https://a.co/d/cqbovXD
